Caller ID - Disable per extension
pcmis
Are you able to disable caller ID at the extension level or ring group level? We have a ring group where we dont want the users to see the incoming number in an attempt to avoid certain incoming callers.
I am able to turn off caller ID directly on the yealink phones...but if they have the client or web app, it will still show.
Hello @pcmis
Unfortunately you cannot do this at the extension level. This can only be done at the trunk level with caller ID reformatting. So you can not do this based on the destination of the call.
ok...thanks for the response!
fransisco
