Caller ID displaying extension name as opposed to business name. Need Business name to display for all extensions
TDJ211
Im having an issue where the extension name is displaying as the caller id name as opposed to the Business name. Ive set the CNAME on the DID (Flowroute) but am still seeing the extension name as opposed to business name.
Ive contacted flowroute and their response was that:
CNAM will only work if you are sending the 'from' number in your SIP information. It sounds like you have the extension name in the incorrect field.
I do see the extension option but these are the Outbound parameters im currently using in the "from" number section.
"CallerDispName" Display name of a caller as it is in From Header - Provided by phone settings
"OriginatorCallerID" Original Caller number will be sent
"GWHostPort" gateway/provider host/port
i have this problem also
migrated from on premise to cloud and its broke now... wasnt broke before
bosdorf
