CallFlow App with no DID - which office time take?
Simone_R
we use a Call flow to manage internal calls two intercoms on a gate, so the app has no DID assigned.
Is it assigned by default to the main department or none?
As for now, CFD apps are system wide, that is, not assigned to any department. If your app is using the Date & Time Conditional component to check the office hours, it will use the values from the default department.
In a future update we will let you move CFD apps to a specific department, and then it will use the office hours of that department.
Reactions: EmmettsIT
