- Joined
- Jan 10, 2022
- Messages
- 14
- Reaction score
- 1
A 3CX PBX was installed for a client yesterday. One extension reports that when they try and call a mobile or landline number back by double-clicking the contact under 'missed calls', the system starts to make the call but it is dropped after a second.
If the same extension dials the same number directly (rather than double-clicking a number in the missed calls list) it works fine.
The activity log shows the following:
Any suggestions, please?
| 03/10/2022 3:18:45 PM - Call to T:Line:10001>>7825703265@[Dev:sip:[email protected]:5060] from L:793.1[Extn:6000] failed, cause: Cause: 404 Not Found/INVITE from 88.215.51.197:5060 |
| 03/10/2022 3:18:45 PM - [CM503003]: Call(C:793): Call to <sip:[email protected]:0> has failed; Cause: 404 Not Found/INVITE from 88.215.51.197:5060 |
| 03/10/2022 3:18:39 PM - Call to T:Line:10002>>7825703265@[Dev:sip:[email protected]:5060] from L:792.1[Extn:6000] failed, cause: Cause: 404 Not Found/INVITE from 88.215.56.225:5060 |
| 03/10/2022 3:18:39 PM - [CM503003]: Call(C:792): Call to <sip:[email protected]:0> has failed; Cause: 404 Not Found/INVITE from 88.215.56.225:5060 |
| 03/10/2022 3:18:39 PM - Call to T:Line:10001>>7825703265@[Dev:sip:[email protected]:5060] from L:792.1[Extn:6000] failed, cause: Cause: 404 Not Found/INVITE from 88.215.51.197:5060 |
| 03/10/2022 3:18:39 PM - [CM503003]: Call(C:792): Call to <sip:[email protected]:0> has failed; Cause: 404 Not Found/INVITE from 88.215.51.197:5060 |
| 03/10/2022 3:18:34 PM - Call to T:Line:10002>>7825703265@[Dev:sip:[email protected]:5060] from L:791.1[Extn:6000] failed, cause: Cause: 404 Not Found/INVITE from 88.215.56.225:5060 |
| 03/10/2022 3:18:34 PM - [CM503003]: Call(C:791): Call to <sip:[email protected]:0> has failed; Cause: 404 Not Found/INVITE from 88.215.56.225:5060 |
| 03/10/2022 3:18:34 PM - Call to T:Line:10001>>7825703265@[Dev:sip:[email protected]:5060] from L:791.1[Extn:6000] failed, cause: Cause: 404 Not Found/INVITE from 88.215.51.197:5060 |
| 03/10/2022 3:18:34 PM - [CM503003]: Call(C:791): Call to <sip:[email protected]:0> has failed; Cause: 404 Not Found/INVITE from 88.215.51.197:5060 |
