- Joined
- Aug 24, 2007
- Messages
- 64
- Reaction score
- 4
Starting with Chromium Version 83.0.4103.116 (RPM Fusion Build) (64-bit), everything looks ok until you try a call (either out-bound or received), when the client page will crash with browser error "256".
Browser help link (which connects to Chrome help rather than being Chromium-specific) indicates trying to clear browser cache/history, etc, which I have tried (using the 4 weeks option).
I only have 2 extensions in this particular browser, and tried disabling both of them - same problem. I then also tried a full Settings Reset. No good still.
The client worked perfectly in the previous version of Chromium - it's only since the last update (week or so ago?) that this crashing started.
Using "regular" Chrome (Version 83.0.4103.116 (Official Build) (64-bit)) is still OK at the moment. Without this working I would be without any ability to use 3CX remotely (can't currently use Android app as this insists on v.16 and we are still on v15.5 for a while longer).
I'm concerned that the next Chrome upgrade may also break calls the same way Chromium now does - leaving me totally without 3CX regular calls ability.
I would also like to see Firefox working 100% - but that has issues with various features in the onscreen active-call panel not operating - e.g. in-call Keypad button and transfer buttons simply locked off, so can't use it, even for voicemail - so using this for any extension dialling/forwarding or similar dial-tone based menu's is out. Shame for such a widely-used/popular browser that also supports WebRTC in other areas.
Has anyone else had similar issues? Or can offer a fix other than relying on one specific browser only (or updating server to v16, if that even makes a difference)?
[We will move to v16 at some point, but timing of doing this when everyone is remote and relying on it is difficult.]
TIA,
Alec
TIA,
Alec
