calls not gose to any of ip phones
Ahmed Mohamed
04/16/2021 10:24:25 AM - [CM503003]: Call(C:52): Call to <sip:2000@XXXXXXX:0> has failed; Cause: 487 Request Terminated/INVITE from 49.199.224.XXX:54355
cant get calls
all calls gose to Voice Mails
ProductStandard Annual
Version Number16.0.9
  • Is the 3CX Server Hosted and where? Cloud
  • Fanvil X3S 2.12.0.7275 FW
  • Method STUN
  • Trunk Provider or Gateway Make/Model :INTERNODE
Same with Cisco SP303A FW 7.5.2
I added different sip port for every phone and different RTP ports as well
1. Check if the phones have registered, they will appear in the Phones page. You can call *777 echo test to see if the phone works firstly.
2. Please follow this guide since you are using STUN mode
actually i did this but i have a question should i write same ports in the phone menu ?
Is the phone registered? and Can it call *777 an hear your own voice?
all phones registered and fine can hear my self
Great that's a good first step. Next, look at your extensions and make sure they are set to Available
1. Go to Extensions from your management console
2. Select the ones you want (or all of them)
3. Click Status button on top
4. Select "Available", then close the status box
Now call one extension directly from one phone to the other.
If you cannot control all the requirements, and in that case you should consider abandoning STUN mode, and instead use the 3CX SBC which solves many of the problems you might have with STUN.
i didnt use SBC before and i tried to use it before but never works out with me
Finatra.us
