Can connect with SSH but can not connect to management console
Mitch Fairbanks
I have forwarded the port like the above but still can not access management console when i try to navigate in Chrome browser to Http://127.0.0.1:45000. Says in "Cannot be reached". I have tried changing from 45000 to others still no luck. Any suggestions?
The webserver only works on https port, if you are using 5001, try to get that to work
If this is a snip of port forwarding why are you using destination as 127.0.0.1 and not the 3cx server ip sddress The port has to be 5001 and not 45000 (you can not translate the port number)
Portwarding only works when external to the 3cx server.
More info on 3cx portwarding https://www.3cx.com/docs/manual/firewall-router-configuration/
If you are on the same network as the 3cx server try http;//3cx server IP address;5000
I just ran followed the guide and was able to connect:
From your SSH connection, can you check that the 3CX services are all running (other than the hotel module)? service 3* status
fngl
