Can I make internal calls if on-prem server does not have an internet connection.
Akshay_Ramlackan
I need to set up a new PBX for client in a remote location where internet connectivity can be a problem.
Can I still make internal calls using an on-prem server when there is no internet connection?
Yes, if the PBX is up and the extensions are registered locally. However, if the PBX cant activate with the license server you will lose functionality. Note, you wont be able to install the PBX without internet.
Reactions: jed and OlegR_3CX
You will have to ensure that activation is working, else as mentioned by a colleague above, the 3CX System will lose its functionality.
Thank you, is there a way to ensure that the activation is working even if the connection drops for an extended period of time ?
Activation will be changed randomly so if it won't activate, it will retried again later on.
How often does it check in with the license activation server ?
It is a random check during the day.
BillyAkansel
