Can I push a custom config file to all my phones? (Change default ringtone etc.)
Stulander
We have Snom D717s. There are some things I'd like to change like the default context-sensitive buttons, ringtone, etc. One of the default buttons shows "Help" and when pressed it tells you to visit the IP address of the phone in a browser or to go to service.snom.com. I'd like to replace the message shown, or just change the the function of this button from "help" to something else entirely. This is easy enough to do per phone, but can I push this change system wide?
You would need to take a look at EXT settings as there are a few things you can configure for the phone(s) in there such as ring tones. Otherwise, everything else will have to be made via custom templates which can be modified from MGMT console > Settings > Templates.
PS - I imagine your signature might get you in to trouble on here.
Thanks.
I've posted in a few threads and had some 3CX employees respond and didn't get called out but changed the signatured anyway.
Ah, I had multiple phones selected and it wouldn't let me change the ringtone. Guess I have to do them all individually. :confused:
hughesdouglas
