Can I use Polycom CX5000 with 3CX?
Kane Wong
Hello;
I have a Polycom CX5000 video conferencing system, this is great for using Skype because it come with 6 cameras, the drawback is that it is not a VOIP device, the phone is just using analog line. I want to know anyone tried using Grandstream HT801 for the analog line device in 3CX environment?
have not tested HT801, but if you need less than 4 ports (perhaps for your use only one is enough) you can set a Cisco SPA 112 , only 2 ports, works perfectly even if not 3CX supported, you just need to set it manually as it has no 3CX template to be provisionned.
