Can i use Public IP in Elastix?
nareach
Forum User
Today i have Elastix Server in my Lan via ip: 192.168.88.150.
and now i want to use it as public ip that can access anywhere.
I have one public ip and i use Mikrotik Router.
Any comment?
Hi.
You need to forwarding SIP and RTP ports in your router to your Elastix server.
Next, configure the NAT into Asterisk SIP Settings from Freepbx GUI.
Next, put nat=yes into each object connected from the WAN (Trunks, extensions).
The NAT should be correctly configured of course. externip=your_ip_public or externhost=your_host_name
Read some threads into the forum using the field Search on top of right of this page.
Or download and read the documents Elastix Easy and Elastix Without Tears for the common configurations
I Still do not understand, i am new in elastix. so please explain me or screenshot me how to config in MikroTik Router.
I don't know MikroTik router, sorry.
In any cases, you should have some parameters to forwarding some ports (sip and rtp under UDP) to a specific IP address.
About Elastix, like i said :
..download and read the documents Elastix Easy and Elastix Without Tears for the common configurations..
There's several threads on this forum about NAT configuration. Start to read them. Next, if you have any problems again, let me know.
Ok, i will try.
