can not hear voice in two direction
dwaik
i configure 3cx and everything is okey ,i also configure goip gateway and it is fine.
i create sip trunck for local provider ,and the sip goes up and connected,when making call , the call is fine but no one hear anything in the two way .
what is the problem ?
my system admin confirm that no ports closed and the sip provider tell the same.
What is your set up? Is 3CX hosted on the local LAN? If not, do the sets use an SBC, STUN, or VPN? Does the 3CX Firewall test pass?
hughesdouglas
