Can not set time zone.
Chris Rizzuto
My 3CX instance has no time zone set. When I try to set a time zone, I try to pick it from the list of zones and then hit OK.
I immediately get the following error:
Object reference not set to an instance of an object.
Thank in advance for any suggestions to fix this problem!!
Cheers,
Chris
  • 3CX Version, Standard Annual 16.0.5.454
  • Hosted with Ixica
  • Has the Firewall Checker passed: YES / NO
  • Are custom Phone Templates being used: YES / NO
This has been an issue since the first day. Doing updates has not made any difference. I dont want to have to create another instance although I know that would likley work.
