Solved Can not transfer incomming calls and when press transfer is not on Hold
giorgosbmc
for unknow reason ( i dont know) we can not trasfer incomming calls from extension to other plus when we press hold or transfer button caller not hear the hold music. when press transfer the call goes to other extension ( is ringing) but when we pick up the line is empty(drop)
is anybody help or suggest what i can do ?
PS we have 1 softphone + 3 devices - all posible wait tested - that means is not device of software issue but from 3CX
On your trunk options tab, disable "Supports Re-Invites" and "Supports Replaces" and try again please
Reactions: giorgosbmc
Hi John ! thanks a lot !!!! issue fixed when i disable the " Supports Re-Invites ".
THANK YOU !
Reactions: JohnS_3CX
Glad to hear it was resolved
Kayla Norris
