Can SBC be installed on virtualbox or VmWare workstation
voice11
Hello everyone.
I have 3CX Debian (V15.5) on VmWare workstation 14 Pro (14.1.0), running on WIN7 pro SP1. Now I am planning to migrate in to the cloud (probably google unless someone suggest otherwise). I have question to what do I need to setup a SBC? I am inclined toward Linux (or may be windows too if I have to) but my dilemma is weather I need a dedicated machine to download that onto ....or can I use an existing server and install SBC on a virtualbox or Vmware workstation on there and use it that way. Can someone clarify this for me please? I tried installing both (Linux & Window based SBC) on virtalbox but it comes back as unsupported file. Virtual box can not read it.
Did you setup a new virtual machine - windows or debian ?
You install SBC within the virtual machine
How many extensions will you have on the remote site?
We generally use Raspberry Pi's for SBC if there are less than 15 phones.
Yes I tested on virtaulbox. Tried both separatelylinux as well as windows and downloaded SBC (both linux based as well as windows) but couldn't install as it said unsupported file
I will have between 10 to 15 actually. Since it close to threshold I thought to go with WIN or linux but I am open to raspberry as well... Thank you.
SBC install files are not virtual images that can be loaded directly into HyperV or Virtual Box as you are trying to do in the screenshot
You need to setup a windows machine in your virtual box, when done log into this machine and download the 3CX installation file within the windows machine - https://www.3cx.com/docs/3cx-tunnel-session-border-controller/
Reactions: voice11
Ah...ok. Thank you @Saqqara. You mean in Win based VM, I need to install WIN OS..right? Then obviously once its a window machine, then download SBC directly into there, right?
And can samething be done with Linux based VM? With Linux based (if possible) you save hassle & money of installing windows OS. That is why I was trying debian VM. Thank you again.
aatroxadrian
