Can the Aastra 51i be provisioned on 3CX?
Fred2k
I'm getting mixed feeling about this. In this list of supported phones it's not listed, however when you go to Add a phone (I'm on V15.5) it's there in the list under the heading "End of Life" which, to me, suggests it is compatible, at least to some degree:
I have read the How to configure Aastra 67i Series for 3CX article which has a link to firmware for the Aastra 675i, but no mention of the 51i. So first question, does anyone know if Firmware versoin 2.6.0.2019 is ok for the 51i?
Incidentally I have also followed this article on how to provision Aastra phones but it didn't work - not necessarily surprising if I need Firmware version 2.6.0.2019 though
Hello @Fred2k
Please note that in the first guide you mention there is a link for downloading the supported firmware for these devices, and the 51i is included. Not sure exactly what version that is as i do not have access to an Astra 51i currently but that is the one you should be using. If i remember correctly it is version 2.6.0.2019.
Ok thanks - I just wanted to double check as the 51i isn't explicitly mentioned anywhere on that page, and I didn't want to kill my phone in the process!
I guess it's version 2.6.0.2019 since when you add the phone from 3CX it's listed as 51i/6751i suggesting they're handled the same way.
Download the files and use those to provision the phone. The phone will pull the correct file.
Well, I wasn't able to upgrade the firmware via HTTP, however I did manage it using this Pumpkin TFTP method, so I now have firmware version 2.6.0.2019 loaded :)
Unfortunately I'm still having no joy provisioning the phone automatically. I factory reset it, added the phone with MAC address to an extension in 3CX, and set the Configuration Server as per instructions in this article, but when I restart the phone nothing is happening.
I was able to register the phone manually by populating the Global SIP Settings, however this is fairly tedious and I have several more Aastra 51i phones to configure, so if anyone can help me figure out how to get it to pick up the settings automatically I'd be very grateful!
RemyDijke
