Can u provision with a static ip?
robort
Forum User
Our dhcp server is down ( dont ask ) so i need to provision a phone with a static ip for now. is there anyway of doing this? its a yealink t19
thanks
Not if phone does not have an ip address.
Yes set to factory if not already, then from the menus on the phone itself you can select network and input the ip and other required info using keypad. Don't recall if you have to enter username and password but if you do it should be u=admin p=admin
Jacob.Ive
