Solved Can you manually update the SSL Certificate?
cam
We were testing turning off the 3cs server at night to reduce costs and we believe that has stopped the SSL certificate from updating.
Is there a way of manually updating the certificate?
We have it on Azure Debian VM
Latest version
We start the renewal process 1 month before the expiration of the SSL certificate. You would leave it on at night at this period, so then the certificate gets updated.
Reactions: GregG_3CX
I have changed it to not shut down now, will it update over night now?
Yes, this will perform the update in the early hours of the morning, at about 2-4 am
So, we wont be able to force it to happen during the day?
You can, but this requires going into the parameters of the system, as well as command line.
I would not recommend this unless absolutely necessary, and only if the automatic procedure fails multiple times in a row.
The SSL certificate updated over night, so we are Ok now
Reactions: NicholasP_3CX
x1515
