Cannot access hosted instance of 3CX
eterprizeit
How can I find if there is an issue with my hosted instance of 3CX ? Who should I contact and how?
Can you please clarify if you still experience the issue?
This seems that was an issue with the ISP as the machine was up and running.
In any case good to know you are able to reach it now.
If you run into this issue again try to disable IPv6 and then try again. We had similar issues and that was the issue.
Reactions: Natassia Allery
Hello @eterprizeit,
To answer your question in regards to whom you can contact, you can:
1. post in our Hosted forums as you already did and our Hosted team members will review your query and assist you.
2. Contact [email protected] if you believe this is a licensing matter for your Hosted by 3CX system.
3. Technical matters for hosted by 3CX instances can be mentioned in the forums and by opening a support ticket to our Dedicated support team.
If you decide to open a support ticket, please check our support procedures here to make sure you are aligned with our support policies.
Opening a support ticket can be done from your Portal > Support tab.
mazet
