Cannot Access Management Console
MarkCSUK
When trying to access the management console I get as far as the login prompt and then get SERVER ERROR.
The management console service is not running and will not start.
it gives ERROR 1604.
  • 3CX Version, Professional Annual 16.0.6.655
  • Server OS, Windows 10 build 1903
  • Is the 3CX Server Hosted and where? no
any help with this would be much appreciated.
go in windows services and force console service to start.
without any link related to your problem, you could try to push windows 2004 release
as stated in my original post, the console service will not start. It gives Windows Error 1604.
thanks for your reply.
try if not already done a windows reboot
thanks - tried many many many reboots.
is it a fresh pbx install or was it running since a while ?
PC is dedicated to 3CX ?
No antivirus ?
been running a good long while, PC dedicated to 3CX and yes No AV.
since when did you got that problem? after an update ?
If i was you, i will do a complete PBX backup and keep it safe out of that pc, then update my windows to latest v2004, then remove actual pbx, reboot, reinstall from scracth with restore during install.
Thanks, but as we can't get into the management console it's difficult to backup it up.
you don't have any recent backup ?
in eventviewer do you have detailled explaination on why that service is not running?
we have been working on this with 3CX Support (Charalambos) and this is now resolved.
Are you okay to share what you've done to fix it ?
sure,
we used the command line to take a partial backup (no fqdn, no license), we then uninstalled 3CX and unlinked the license from the FQDN (via customer portal). renamed c:\programdata\3CX to C:\programdata\OLD-3CX and rebooted the machine.
We then reinstalled 3CX recreated the 3cx.co.uk FQDN and linked to license (part of the install) - made sure all updates were applied, once everything was latest version we restored the partial backup.
bish bash bosh - all settings & extensions restored, everything working.
Reactions: AWS2P
Thanks for sharing solution ;)
[email protected].
