- Joined
- Jul 26, 2023
- Messages
- 2
- Reaction score
- 0
After some support messages from Flowroute, I have switched from SIP registration to IP-based Auth, and since then I have been able to dial into my 3CX instance, but I cannot dial out. The event log shows the following error:
I am not sure what "AU" means...
It's only dialing out where the issue is. I am not sure what the proper outbound rules I should have set up. I just want to be able to dial 7 to dial out, and I have tried stripping 1 digit and played with appending a country code and an area code, but still nothing calls out successfully.
Furthermore, I have no "Reformat Incoming or Outgoing Caller" patterns setup, and attached is my current config for my only outbound rule.
Code:
Call or Registration to 11234567890@(Ln.10000@Flowroute) has failed. 34.226.36.32 replied: 403 Bad Au - [email protected]; from IP:34.226.36.32:5060
