Solved Cannot log users out of call queue
MrGeezer
I have two extensions logged into the queue.
I am also logged in as one of the extensions on my windows laptop using 3cx client.
In the past, I used to be able to open the Queue manager view and right click on the other extension and log it out of the queue. I am no longer able to do so. Can anyone give me a clue as to how I can pinpoint what is causing this?
The only thing I think may have changed is that the 3cx client / laptop is now connecting to the server via the SBC method as I added one of these to solve remote audio issues I was having. Can't be certain that this problem started after doing that - but it's the only thing I can think that's changed apart from downloading the usual server upddates via control panel etc.
thanks in advance for any clues anyone can offer
Hi @MrGeezer
The clients do not connect to the the PBX via SBC, only devices so that should not pose a problem.
Can you please make sure you are the queue manager of that queue?
Would also help if you state your PBX and client version.
Thanks very much for your response. I did wonder if I there was a queue manager setting but cannot seem to find it. Another thread on this baord suggests in in queue settings->advanced, but can't seem to see it there. Any clue where it might be?
Server version is 16.0.676. 3cx client version is 16.0.1.81
Try logging into the management console as the Administrator, and checking the queue settings from there
Thanks. But i AM logged into the management console as admin!
13234
Oh my goodness thank you so much that's where it is!!! And sure, now I've found it my extensions was not a queue manager. Have added it and now this is working. Cannot thank you enough chaps :)
Reactions: JohnS_3CX
Kayla Norris
