Cannot login into 3cx after self-host installation
Sam Charles
Hi Team,
I have just installed 3cx on OVH, I got the details for all users however I didnt get the details to login into the management console.
Please help!
If you didn't get the welcome email with the password, nor did you note it down on the install finished screen, nor do you have a backup the official supported method is to reinstall after entering in the wrong password 2x and then using the reset password link that appears on screen.
As this is a fresh install I'll assume nothing is in it and a reinstall won't take long.
Thanks. Do i have to unistall from OVH be re-istalling?
*re-install I meant.
mazet
