Solved Cannot Login to Web Management Console
Skavenger
My console url is mycompany.my3cx.us but I cannot hit it to even get a login prompt. I was able to login about 2 weeks ago but not now. I need to get into it to see why outbound calls are all of the sudden failing but inbounds come through. Any ideas?
V/r
Jerry
My console url is jerryhall.my3cx.us but I cannot hit it to even get a login prompt. I was able to login about 2 weeks ago but not now. I need to get into it to see why outbound calls are all of the sudden failing but inbounds come through. Any ideas?
V/r
Jerry
Please don't share your FQDN publicly.
Can you tell us:
1. PBX Version?
2. Where is it hosted?
3. What is your provider?
Reactions: AndreasY_3CX
It is 3CX Hosted
Version 18 Update 1
AWS EC2 is my provider
@Skavenger ssh to your machine and let me know if nginx is up " service nginx status "
Also please make sure that all 3CX services are running.
Execute the following script to start all PBX services:
3CXStartServices
Could you PM me your subscription in order to check further your situation?
Thanks for all your help. I was finally able to get in. What happened was AWS EC2 shut down a site and forced me to a different one. This changed my public access IP so everything was down. Once I figured it out I got the public changed across all the interconnections and it is working.
Glad to hear that your issue has been resolved.
Yes, indeed AWS EC2 uses a dynamic IP address which causes the machine to change its IP address after you bring it back online.
megalmazan
