Cannot make outgoing call
aftechservices
Hi There,
I have just installed 3CX on Debian 10 on a VM (self hosted). My SIP trunk is through Sipgate and I cannot make an outgoing call. These are the outbound rules i have set
Hello.
What error do you get?
Do you hear any message from the provider?
Do you see anything in the Event log of the PBX?
Does your PBX settings (Security>> Allow country codes) have a prefix for the UK? And also, does the provider support the same number format as in the inbound rule?
On the call log it just comes up as "Not Answered"
I have tried copying the same format as the inbound rule (44120*******) to the outbound but still no difference.
Kindly open the ticket with the support so that we will request the files and investigate them.
Thank you
Hi @aftechservices
Also check your E164 settings under the General tab. Based on your outbound rule the E164 should be disabled.
Diogo Maia
