Cannot Purge PBX Logs in v20
Gavino
After upgrading to v20, when I go to "Clear All Data" by selecting "Purge All" in the Maintenance section (see below), all the other items clear to zero, but not the PBX Logs. Is this normal?
Multiple hits to the "Purge" button and also rebooting the PBX via the web GUI doesn't help. This system is managed by a Partner in the cloud - I don't have access to the CLI.
Is there something I can do to clear the PBX logs from the web GUI (Admin Console), or something that the cloud provider can do from the CLI? If so, please let me know and I'll point them to this thread.
I am on Version 20.0 Update 4 (Build 487 Release) Type Professional Annual. Alternatively, I can wait for a patch update. Thank you.
This button deletes old log files but not those that are currently in use by PBX.
OK thank you. 82MB seems a bit big for logs (especially for our small sized setup), but if it doesn't grow over time then it's fine.
Graham Robertson
