Solved Cannot "Regenerate" extension
Callinectes
When attempting to us the Regenerate option to reset an extension and prevent smartphone and web access we are getting a popup window error stating "Object reference not set to an instance of an object."
Never mind - this behavior appears to be caused by having a custom template being used with an IP Phone.
This is what i wanted to mention as well since custom templates can cause this issue.
Glad to know you found it ;)
