Cannot seem to find instructions on blocking CallerID numbers
survivalbloke
Is this a function of 3CX or a function of my SIP trunk? I can't seem to find an option anywhere.
Regarding your question, there is no option for this under the 3CX Free or SMB instances.
oh my god. I can't block numbers, I can't use Twilio... good lord. Thank you Charles.
Sorry to the barrier of bad news to you sir :)
Hi Charles, I just came across this post, Can you double clarify this for me.
You can block numbers on other 3CX versions (paid) but not in the SMB (must affordable) and not in the free version.
Is this accurate?
Is this accurate?
This feature is via the number blacklist section, which is available only with dedicated instances but not on the SMB instances (even if paid SMB PRO).
Reactions: acontreras
Hello Charles,
Will futures SMB PRO releases stick nearer features of a classic PBX or will it be always a light version compare to others?
Silent_Guru
