Cannot select date past 22 June 2020 in V15.
bsstsupport
Forum User
Running V15.5.15502.6 on Windows Server 2012R2.
When running a custom report, I cannot select a date past 22 June 2020 in the date range. I have seen a couple posts about the issue and the solution was to upgrade to the newest V16 release. Does anyone know of a fix for V15? I can't upgrade to V16 at this time due to a couple issues.
Thanks for the help.
This was an issue identified and fixed in Version 16. You will need to bite the bullet and do the upgrade to Version 16.
Version 15.5 is no longer developed, nor supported as of 1st July 2020.
bosdorf
