Solved Cannot Uninstall v15
SpecialK
I'm trying to uninstall v15 (latest ver.) so that I can install v16. The computer is Windows 10 Pro. I followed the instructions to backup the current configuration to a location outside of the v15 folders. I put my backup in c:\user\Documents. After backup, I go to Programs and Features. I double click to uninstall. I get the first dialog box saying that install is starting. I get to the second dialog box asking to click Next to uninstall. I can't click Next, as it is greyed out. I can only click Back or Cancel. I have tried this numerous times, both with 3CX services running and stopped. I wait 10-15 minutes but the Next button never changes so that I can click it. Yes, I do have full admin priv on this computer.
I have done many 3CX upgrades and have never run into this problem. I simply cannot uninstall v15 3CX to then install v16 and restore from backup.
Hi @SpecialK
Try rebooting the Windows 10 system in Diagnostic Mode, and then try to uninstall again.
1.) Run: msconfig, select Diagnostic Startup, apply and reboot
2.) Try uninstalling now
3.) When done, run msconfig again and select normal startup then apply and reboot.
  1. Diagnostic mode didn't work
  2. Hidden Administrator account didn't work
  3. Revo Uninstaller didn't work
  4. Microsoft Install/Uninstall Diagnostic Repair Tool DID work
Hi SpecialK
I'm glad it was resolved, thanks for sharing your solution
devo.it
