Cannot use Jabra evolve 75 bluetooth audio with 3cx Android app
Penthalaz3cx
Forum User
i have issue with jabra headset evolve 75 with bluetooth audio, the device does not take call when we push the button and the sound is not coming back... the same jabra device works perfectly with 3cx app for IOS
any update soon ?
On mobiles we do not provide any specific support on any specific bluetooth headset being used.
We do have an option though under Settings > Advanced called Car/Bluetooth support (Telecom API).
This gives you a choice to switch between using a different API and see which ones works best for you, but the catch here is that the implementation of the API will depend on the phone's manufacturer.
That's basically the reason why it may work perfectly on iPhone but not on say one Android phone - but work perfectly fine on another Android phone.
Mahlon
