Can't access Trunk after upgrading to V20
mayertech
I have several instances of 3cx running on Linux that no longer allow me to view the Trunk under Voice & Chat after upgrading to V20. When I click on the trunk it just goes to the main dashboard, there is no way to make any changes now. Any idea how to fix this issue?
I'm not seeing anything with a way to fix and show the trunk .. I think the instances I have that are having issues were created using a generic sip template that were upgraded over the years back to a very old version of 3cx. Problem is some of the instances have 300+ DIDs assigned to several hundred extensions, recreating the Trunk would be near impossible and I don't even see a way to export or find all the settings so we can recreate it.
If you know the name of the template, then copy a so named .pv.xml file to
/var/lib/3cxpbx/Instance1/Data/Http/Templates/provider/ and modify owner and group of the file
chown phonesystem:phonesystem <file>
Else search it in a 3CX backup xml file in the tag <VoipProvider> / <TemplateFilename> . This file must exist.
If the so named file still exist and the error consists, then post it here.
If you prefer, you can ask a partner like one of us to assist you.
Reactions: N_G
Thanks, I will try this when I get a chance.
priya
