Can't answer call from Yealink Phone
bruceleeon
Client 1
Extension: 3690
Method: Android
Client 2:
Extension: 8893
Method: Yeahlink T46s (Firmware 66.85.0.5)
Followed: https://www.3cx.com/sip-phones/yealink-t4-series/
No SIP, all local for now.
3CX running their ISO for Linux (16.0.655)
Firewall = Green
Trunks = Green
Services = Green
Phones = Green
System Extensions = Green
Symptom: When dialing from Yealink, android client will ring. Upon answering call is dropped. When calling extension of Yealink phone, "not acceptable here" is displayed.
10/08/2020 9:11:28 AM - Call to T:Extn:8893@[Dev:sip:[email protected]:5060] from L:4.1[Extn:3690] failed, cause: Cause: 488 Not Acceptable Here/INVITE from 192.168.1.224:5060
10/08/2020 9:11:28 AM - [CM503003]: Call(C:4): Call to <sip:[email protected]:0> has failed; Cause: 488 Not Acceptable Here/INVITE from 192.168.1.224:5060
10/08/2020 9:11:17 AM - Call to T:Extn:8893@[Dev:sip:[email protected]:5060] from L:3.1[Extn:3690] failed, cause: Cause: 488 Not Acceptable Here/INVITE from 192.168.1.224:5060
10/08/2020 9:11:17 AM - [CM503003]: Call(C:3): Call to <sip:[email protected]:0> has failed; Cause: 488 Not Acceptable Here/INVITE from 192.168.1.224:5060
10/08/2020 9:11:04 AM - [CM503003]: Call(C:1): Call to <sip:[email protected]:0> has failed; Cause: 487 Request Terminated/INVITE from 127.0.0.1:5483
Check your codecs order everywhere:
- Settings > General
- Extension > Phone Provisioning > 3CX App
- Extension > Phone Provisioning > Yealink T4...
Make sure all the same are set, and in the same order.
So, delete anything that doesn't match, and make sure they are in the same order? Just want to verify before I delete things
Just put the 4 first to be the same on each page.
Settings > General will not allow you to delete the others so just put them lower.
Done, No change.
10/08/2020 9:39:53 AM - Call to T:Extn:8893@[Dev:sip:[email protected]:5060] from L:16.1[Extn:3690] failed, cause: Cause: 488 Not Acceptable Here/INVITE from 192.168.1.224:5060
10/08/2020 9:39:53 AM - [CM503003]: Call(C:16): Call to <sip:[email protected]:0> has failed; Cause: 488 Not Acceptable Here/INVITE from 192.168.1.224:5060
Done, No change.
Did you reprovision the phone and the android app?
On each device, make sure there are connected to the 3CX server - dial *777 which is the echo test.
BOOM MOFO WAGON
It works :) Thank you... I had read threads that referenced codecs, but never saw the "same order" piece
prefered order is to stick SIP provider order
nizammoktar
