- Joined
- Sep 4, 2019
- Messages
- 3
- Reaction score
- 0
Outbound calls to 800 numbers are not working. we get an out of service message. Calls to local numbers are not working. We here a busy tone before the call ends. I will list the activity from the errors below.Thank you all!
Call to local number.
| 04/08/2020 1:17:38 PM - Call to T:Line:10000>>17605981776@[Dev:sip:[email protected]] from L:234.1[Extn:111] failed, cause: Cause: 403 IP Based Authentication Required - [email protected]/INVITE from 34.210.91.112:5060 | ||||||||||||
| 04/08/2020 1:17:38 PM - [CM503003]: Call(C:234): Call to <sip:[email protected]:0> has failed; Cause: 403 IP Based Authentication Required - [email protected]/INVITE from 34.210.91.112:5060 | ||||||||||||
| 04/08/2020 1:17:38 PM - Call to T:Line:10000>>52626640*17605981776@[Dev:sip:[email protected]] from L:234.1[Extn:111] failed, cause: Cause: 606 Not Acceptable/INVITE from 34.210.91.112:5060 | ||||||||||||
| 04/08/2020 1:17:38 PM - [CM503003]: Call(C:234): Call to <sip:52626640*[email protected]:0> has failed; Cause: 606 Not Acceptable/INVITE from 34.210.91.112:5060 Calls to 800 Numbers
