Can't connect to Dynamics 365, error with the token
François (tebu-bio)
New User
Hello !
When I click on the button to Authorize, I get this error :
AADSTS50011: The reply url specified in the request does not match the reply urls configured for the application:.
I followed the doc, my app is registered, with the rights to access Dynamics.
Any idea what I could be missing ?
This is because the Redirect URL configured when you created the Azure app, is not correct according to the URL you use to access the 3CX console.
The redirect URL needs to be set to the URL you use to access your 3CX management console, adding “/api/oauth2crm” at the end. For example, if you access your console using "https://mypbx.example.com:5001", then you need to configure the Redirect URL in Azure as “https://mypbx.example.com:5001/api/oauth2crm”. If you access the console using IP address, you need to set the Redirect URL with IP address as well...
Please make the adjustment, and try authorizing again.
I was missing the :5001 part, thank you ! Working fine now. :)
Reactions: edossantos
lastshadow
