can't get gmail reset password
duysop
Forum User
2025/05/07 15:39:32.377|0031|Erro| [_3CX.Mail.MailSenderService] Send mail failed: 535: 5.7.0 Denied
2025/05/07 15:39:32.409|0031|Erro| [_3CX.Authorization.ResetEmailService] Reset password email sent failed
MailKit.Security.AuthenticationException: 535: 5.7.0 Denied
---> MailKit.Net.Smtp.SmtpCommandException: 5.7.0 Denied
--- End of inner exception stack trace ---
at MailKit.Net.Smtp.SmtpClient.AuthenticateAsync(Encoding encoding, ICredentials credentials, CancellationToken cancellationToken)
at _3CX.Mail.SmtpMail.SmtpConnect(ISmtpClient smtpClient, CancellationToken cancellationToken)
at _3CX.Mail.SmtpMail.SendAsync(TcxMessage message, CancellationToken cancellationToken)
at _3CX.Mail.MailSenderService.SendMailAsync(TcxMessage message, CancellationToken cancellationToken)
at _3CX.Authorization.ResetEmailService.ResetEmail(String username, String email, String originatorIp)
You need to check your IP address. The FQDN IP address must be the same as the one 3cx uses to access the internet.
Hello @duysop
This usually happens when the Public IP your 3CX is actually using is different than what you have set in Admin > Advanced > Network.
Please try this:
• Navigate under the Dashboard >> Advanced >> Network
• Set the system to Dynamic IP
• Restart the services of the phone system
• When the PBX detects the new IP address go back in Network Settings set the IP to Static and add the new IP
• Restart the services once again.
Once you do this, wait a few minutes, then go to Admin > System > Email and while you have the "3CX SMTP server" selected, press the "TEST" button to see if it succeeds.
