Solved Can't install on 10th gen NUC
turkeyman
Launching the installer in a 10th gen NUC has lots of issues.
First, the bootloader sets the display mode to some big graphical screen, then entering the installer doesn't swap back to text mode, and due to some display configuration failure, I see 10 tiles of the text mode screen along the top of my monitor, but each tile is only a subset of the pixels, so nothing is readable.
I have tried this on many monitors, it's definitely the display mode not working properly with the NUC's display device.
After that, trying to operate the installer blind, it gets to what appears to be network configuration failures... I don't think the 3CX image (debian based) can see the NIC at all. I think the NIC in the NUC requires a modern driver that's not available in the 3CX debian base.
I gave up from here.
I really want to use this NUC as my BPX.
This is not a 3CX issue. Go to the Debian forums to find out what you need to do to get Debian 9 working on that NUC.
Exactly. Thanks!
Reactions: NickD_3CX
intoxtech
