Can't provision Snom PA1 / How to use Snom PA1 for Paging Extension & Overhead Ringing
Josiah Salser
I am having issues provisioning my Snom PA1 much like the 2 posts below, but I don't see that they ever found a resolution.
https://www.3cx.com/community/threads/unable-to-provision-snom-pa1-https-problems.61903/
https://www.3cx.com/community/threads/provisioning-snom-pa1-troubles.58778/
The paging adapter is remote with the PBX being hosted in the cloud so I am trying to use Direct STUN. I have already upgraded to the current firmware 8.7.5.75 . I put in the URL into the Advanced>Update>Setting URL and the device reboots but does not provision.
I should also note that I have factory rest the device and tried to use it with an SBC but it does not show up in the phones tab even though other phones do. Not sure what else to do.
Also, I am trying to use this device for both a paging extension and an overhead ringer. As I understand it I would have to have 2 separate extensions for this purpose and use the 2 identities in the Snom. One of them being set NOT to auto-answer. Is there a way to provision both identities via the management console? And even if there is not, how do I need to configure my remote firewall for the 2nd identity?
