Can't receive incoming calls on S21 Ultra
pscs
SOHO User
3CX v18 update 9 (build 20). Android app 20.0.0
in the past few days, my 3CX app doesn't seem to handle incoming calls correctly.
It knows there's an incoming call, because the availability icon & queue icon disappears when there's an incoming call - but the phone doesn't ring and I can't answer the call
If I enable 'Car/Bluetooth support' in the app, then my Samsung WATCH rings when there's an incoming call - and my phone rings in sympathy with that. I still can't answer the call on the phone, but I can answer it on my watch, and then talk on the phone (but my watch is linked in with the call as well) - it's very odd.
It used to work fine, but now doesn't
I can still make outgoing calls OK.
I did set 'silent mode' on the app a couple of weeks ago, and then unset it later. I cleared the app data & cache in case it was still in 'silent mode' somehow. I've also uninstalled and reinstalled the app and reprovisioned. But it still isn't working.
Hi there.
If you enable the settings "Keep active", does it work and you can receive the call?
No. I tried that - makes no difference whatsoever.
As I said, the app (at some level) *knows* there's an incoming call - icons disappear, and it notifies my watch - it just doesn't ring and give me the option to answer the call.
@pscs can you navigate to the following
Hamburger menu settings [Top left corner] > Settings > Advanced
Scroll down to Notification, audio & visual settings, is Answer on lock screen enabled?
Yep, that's enabled
(and I'm not on the lock screen, I'm looking at the dialer screen while I use my wife's phone to call my DDI number)
@pscs did you check on the latest update of V18 PBX?
18.0.9.31
Could you kindly enable Verbose logging and reproduce the above issue?
Hamburger Menu (Top Left) > Settings > Advanced > Scroll at the very bottom and enable Verbose Logging
Reproduce the test
Send the log report
Hamburger Menu (Top Left) > Settings > Advanced > Scroll at the very bottom and tap on Send log report
Please send the logs to me personally via direct message
cvanderzwan
