Solved Can't start conference call
rvoosterhout
Hi everybody.
I just tried to start a conference call, but i can't seem to connect. I'm starting an ad-hoc conference call using the 3cx client. I fill in a subject and add the phone numbers in the participants field.
When I click start now, it says failed to connect at all the numbers it tries to call. I notice that it doesn't even try to call the number, it goes straight to failed.
When i want to elevate an existing call to a conference call, and add other phone numbers to that call I get the same problem, however the original called number is connected to the conference call. I just can't make outgoing calls from the conference to new phonenumbers. Is there a setting I forgot to set?
Thanks!
Found it already, didn't have an outbound route for extension 700.
Glad to see the issue has been resolved and thank you for sharing your solution
Mr_IT
