Can't use Windows Popups to answer calls
MaFa
SMB User
We're receiving calls, but I'm not able to use the Windows Popups to answer them. Just nothing happens, when I click on it.
As I found in other threads, this may be due to the fact that the app runs in elevated mode.
How do i turn elevated mode off?
I can't find a way to do that. I installed 3CX from Microsoft Store and it immediately starts elevated.
Whenever I found information on this topic, someone says that you have to switch to non-elevated, but it's no where described how to actually change that.
You’re saying you get a UAC prompt when running the Store app?
None of the clients need elevation.
no, we don't get the prompt.
It just starts with windows in autostart and is elevated
Isuru Eranga
