Solved Cause: 302 Moved Temporarily/INVITE
GueZ
I have a problem with an extension in a client, nothing changed since yesterday and yesterday the extension can't receive calls from internal and external.
failed, cause: Cause: 302 Moved Temporarily/INVITE
Is a Linksys SPA-942
If this phone is not registered and the extension is registered in another device it works but when this device connects to this extension does not work anymore.
Already remove and made again the extension with the same configuration and does not change anything
Any ideas? =/
Problem resolved with a colleague we donne a troubleshooting, and when we changed the SIP TCP PORT Min and Max and RTP Port Min Max all ok again.
Is strange because it worked like this for years =/
Glad to see the issue has been resolved and thank you for updating the thread with your solution
Rhameez
