CDR copy to Windows
Simone Rota
Forum User
Hi, I'm Working with 3cx on Debian.
What's the best way to copy o create the CDR file in a Windows Shared Folder?
simone rota
Not sure what the best way is - but one way is to send the CDR's over the network and to collect on another Windows device. For example, if you set the CDR mode to '3CX CDR service is server / Passive Socket’ then you can collect using a suitable program, for example this.
Another option is to use a sync/backup tool such as GoodSync to backup the CDR files via SFTP to a Windows share.
Cron job to an SMB share
hughesdouglas
