CDR Log v16 cloud standard
cookie
On the cloud version the call log only goes back 90 days, how can I obtain the call history beyond this?
v16 standard license
The call log will go to 90 days.
If you want to see more records you must generate a call report.
Dont think I have the option with standard license, call report menu missing, any other way?
Reports are available in Std. But, you wont see the reports available in Pro.
Edit: I tell a lie.. must have changed.. Apparently not available in Std.
https://www.3cx.com/ordering/pricing/
You'll have to upgrade your edition.
[email protected].
