CDR to SQL Table...
Simone Rota
Forum User
What is the best way to send CRD Socket to SQL Express Table? I need some software to to that?
Thansk
Simo
You would have to write an SQL application to read the CDR file and import it
https://www.3cx.com/docs/cdr-call-data-records/
That's the easy part, then you would have to create reports , views etc with SQL to process the data as required.
Thanks!
I have a 3cx installed on Linux and a SQL express in a windows instance.
I would like to be able to send the CDRs directly to a SQL table. Can I install the program on Windows or do I have to work on linux too?
florentrobineau
