CFD transfer from a menu to another (defined inside the same CFD)
Stefano_Finetti_78
In the CFD I am designing for a telephone exchange of one of our clients, the first step is to recognize the caller's number by querying an endpoint.
If the number is recognized, everything seems to work correctly: the user accesses a looping IVR menu that allows them to navigate through various options.
What I am struggling to configure correctly is the case in which the number is not recognized by the endpoint. Currently, the user is redirected to another menu, where a message asks them to press "1" if they are still authorized to access the main menu; otherwise, they can hang up.
In theory, by pressing 1, the user should be transferred to the looping IVR mentioned above. However, instead, the call drops, and in the log, I find:
C:53 Transfer request by L:53.3[Route:900@{}{a8f48048b964}] cannot be performed: no valid target
I had assumed that the transfer should follow this syntax, which is apparently incorrect (see attachment).
Does what I’m trying to do make sense? Or am I approaching it completely the wrong way?
No, you can't do that. The Transfer component lets you transfer the call to another extension in the 3CX server, not move the flow to a different part.
In order to do what you need, I would recommend that you create a custom component (from the Project Explorer add a new component). Then, move your entire menu loop inside that component. Finally, add this custom component to both branches where you want to use it.
That was exactly what I needed. Worked at first try. Thank you!!!
circusduck
