CFD - Unavailable for 3CX hosted environments?
FinlandTechnology
Our client is on 3CX Pro (v20) and 3CX hosted. I just noticed there is nowhere in the admin portal to upload a CFD file?
What are the best options? Should I use the call processing scripts instead? Also, does anyone know of any reliable contacts that work on 3CX call flows for T&M.
Thanks!
Call Scripts are where you upload your CFD.
Go there, click Add+ and use the second option to upload a Call Flow Designer output ZIP.
For reference check steps below as well:
KylieWilderman
