CFDs in v18 on Windows
Tomas Raska
Forum User
Hallo,
we have in 3cx v16 on Windows some CFD.
Is v18 full compatible with CFDs from v16?
Thank you
Hi @Tomas Raska,
Yes, the v16 CFDs will be compatible with v18 systems. However I suggest always running the latest version of the PBX and CFD, so my advice here is to update your PBX all the way to the latest build, update the CFD, and then rebuild your projects using the latest CFD just to keep them updates with the latest build of the PBX.
Something to check out: https://www.3cx.com/blog/releases/call-flow-designer-v18/
Hallo,
Thank you
Hi @Tomas Raska,
Just to clarify:
V16 CFD will work on V18.
V18 CFD WILL NOT work on V16.
Reactions: VasilisV_3CX
Rebuild of the CFD with the latest CFD is mandatory.
Zexus
