Solved Change extension from 100 to 0 for a specific phone
BleronDRGZ
Hi 3CX,
In an actual 3CX system, I use 3 digits extensions. Now, there is a request to switch from number 100 to 0 for reception.
Phones are Fanvil X3SP.
Is there any way to achieve it ?
Best Regards.
Nope
You cannot change the llength of extension digits on a installed 3cx
Try this
In General Settings > Network > FQDN you have the option to enable this
Under Extension 100 > Options > Options > SIP I’d set this to 0
I went by @Saqqara instructions and it was exactly what i was looking for. Thank you!
Reactions: VasilisV_3CX
Glad to hear that's worked for you @BleronDRGZ, feel free to open a new thread if you require any further assistance or information!
Bluebox Global
