Change extension number
Chin007
Intermediate Cert.
We just upgraded to a paid 8u license and was able to easily integrate with O365.
Was surprised to see it created extension numbers starting from 000 even when i already created operator to be 400. I expected the import to start from 401.
Is there a way I can rename/change the extension number?
What i have done to solve the issue:
Stop the sync of users in O365. Settings>O365>User Sync. Removed all the users.
Delete all the extensions starting from 000.
Recreated all the extensions with the correct extension numbers.
Settings>O365>User Sync> Selected uses to sync.
It did not change the extension numbers.
I really wished there was an easy way to do this especially if you have more than 100 extensions. Luckily this client was just 25 extensions.
Update to U6. You will be able to choose the starting number.
It was released this morning.
Reactions: edossantos
awan05
